1960 40hp Evenrude Lark II Ignition Cutout
Ancient Mariner
I recently installed a new ignition switch. I have power going to it and one wire going to the solenoid. The engine cranks fine but how do I set up a kill-switch? Sould there be a wire running to ground off the ingniton switch? :confused:
Lark40
Re: 1960 40hp Evenrude Lark II Ignition Cutout
I have a separate dashboard kill switch that simply grounds the points together.
Paul Moir
Mabey this might help you. Ignore what they say about the ground wire on the switch, and the black/yellow stripe wire. Instead, connect each magneto wire (should be black) to a 'M' terminal. They should do exactly what Lark40 said.<br />Hope this helps!
Ancient Mariner
Thanks I will give these tips a try as soon as I get it running. I still have the factory wiring harness so it may be a challenge figure out which wire goes to the magnito from the junction box. I noticed some black wires going to the vaccum cutout on the port side.
