1958 QD-19 tiller
Lars_1966
I recently got my dad?s 1958 Johnson QD-19 10 horse outboard. I believe my dad bought it new, he has had it as long as I can remember, I have many fond memories of fishing with him and it. The motor has been sitting in a shed for 25 years and I am trying to bring it back to life. It has no spark in one cylinder which I am assuming is the coil, I am working on that. The other issue is the throttle seems to be stuck. I removed the plastic grip and tried to move it gently with some vise grips on the rod and got nothing. It seems to be binding from the grip to the gear in the tiller itself. I can get the corresponding gear to move a little (where it folds). I was wondering if there was some lockout mechanism on these motors or is it simply rusted. I?ve been applying WD-40 and getting nowhere. Do I have to remove the tiller? How is that done? The tiller seems to be made up of two halves held together with one large screw and two small ones. Will removing these screws allow me to see the rod and any problems? Thanks.
Honorary Supreme Mariner
Yes, take that handle apart.--You should install a new waterpump impeller.---Likely 2 new coils.----------Fuel tank repair kit too.
lindy46
Try disconnecting the link where the throttle connects to the magneto. See if the twist grip moves with it disconnected. If it does, the problem is in the magneto. I've seen magnetos froze up after years of storage, due to grease underneath the magneto plate hardening
Lars_1966
Thanks for the responses. Yes, I have two coils on order, I hope that resolves the no spark issue. I'll look into the water pump.
So, there is no lockout mechanism? Like, it has to be in nuetral to move the handle to the start position? There doesn't seem to be and shifting from nuetral/fwd/reverse does not help.
I can move the throttle mechanism at the magneto. It does seem to be frozen only at the handle which seems odd. I will try to take the handle apart when I get home.
There is a lockout mechanism to prevent too much throttle in nuetral and to prevent shifting to nuetral from forward at wide open throttle.
oldboat1
The lockout mechanism is on the shifter side. You can see the linkage move when you move the shift lever. The tiller handle connects to a vertical device on the tiller side -- called the tower. The tower is attached to the throttle plate by a brass arm -- held in place by a clip that is a little delicate. At the bottom of the tower is a gear that engages with the tiller handle. That gear can be stuck, or a tiny spring down at the gear may be rusted (spring provides tension to help keep the tower in place).
edit. parts blow up would be helpful to get a sense of what you are looking at.
F_R
No Title
Lars, by your description, the #24 throttle gear/shaft is tight in the nylon bushing due to corrosion. Sorry, but spraying it with miracle cure won't fix it. You'll have to take it apart and clean the corrosion out and re-lube with some quality waterproof grease.
Lars_1966
Thanks for the picture F_R. Yes, that sounds like my problem. I just hope I can get the screws out, they're rusted pretty good.
oldboat1
Wow. Made to order. (#32/107 would be what I was struggling to describe -- but source of sticking would be what is shown in the diagram, not what I was describing.)
HighTrim
Great write up Frank!
In addition to that, as stated, many times is the mag plate as well where the old grease has dried up. I take all these items apart, clean, and re grease on every new motor to me. Especially under mag plate. On the tower, there are 2 brass plates that hold it straight, clean re grease there as well as the brass arm pivot point which attaches to the tower. After all that, you will have smooth, even throttle.
While you mag plate is off, and you are installing new coils, order about 5' of copper core, 7mm plug wire as well. Polish the points, and set to 020.
As racer stated, change the impeller before you fire her up. She is likely dry rotted by now, and you will have chunks stuck all throughout your cooling system if you try to fire it as it sits. You don't want to have to do that trust me.
Give her fresh gear oil, and get 2 new crush washers.
Before you do anything though, step 1 always test compression.
Lars_1966
Thanks High Trim,
The first thing I did was put a little oil down the spark plug holes and then I did a compression check. I got 75 PSI on each. Does that seem a little low? They are both the same so that's good.
HighTrim
It could be just fine. main thing is that they are even. All gauges read differently.
I would pop the bypass covers, starboard side of powerhead, and rotate the flywheel until you see the piston rings. Push on them with a small screwdriver, they should bounce as you press on them. If they are stuck, running it with seafoam, or engine tuner, could free them up.
