1958 johnson 35 hp
1rich
hello all my name is rich iam new to iboats i just got me a 35 hp johnson motor really cheap now to get it running i changed the coils points and condencers . now iam in need of a gas tank with a primer button .<br />A steering wheel for my 1969 sea king.<br />the pullies for the steering are on the boat allready and in good shape.<br />would like to know if any one has for sale the plug for the starter .and any info on this motor would be great thank you all so very much .....1RICH
OBJ
Re: 1958 johnson 35 hp
Rich....first....welcome to iboats forums.<br /><br />First thing to do if you are serious about the old shaker is get a service manual. For that old an engine, check out the link below for a reprint of the original manual. May not hurt to get a parts manual to.<br /><br /> http://ww3.kencook.com/evinrudejohnsonmanuals/ <br /><br />Have you done compression tests yet? Would be a good idea. Don't want to put a chunk of change in her to find out the cylinders are shot.<br /><br />It would not hurt to rebuild the carb and install a new water pump impeller in it also.<br /><br />The old two hose gas cans are still around. Check out ebay. Once in a while you can pick them up there. May be a little tuffer getting a wire harness. Maybe one of the other guys on the forum will check your post out and give you a lead.<br /><br />Hope we've helped.<br /><br />PS....don't solicit to buy...Mods don't like that. Solicition to buy or sell is vorbot here.<br /><br />Good Luck!<br /><br />Here' another place to check for parts.<br /><br /> http://www.twincityoutboard.com/
NDSSS
Hi<br /> Check out<br /> Larson Marine <br /> Lake Metigoshe<br /> Bottineau N.D<br /> Dont have phone number as I'm at work <br /> but they also have parts for the older motors.<br />Really GOOD GUYS
JB
Hi, Rich.<br /><br />Welcome to the board. Good advice above.<br /><br />A good source for used parts for older engines is www.twincityoutboard.com<br /><br />Good luck. :)
1rich
thanks guy i got her working and i e-mail thats link man thank you all so much ........Richard
