1957 wiring diagram
jwlefevre
I found a 35 seahorse for my vintage Crestliner restoration and need some help with the wiring for electric start/choke. I have the solenoid box and cable but need a better diagram to figure this out. Any help would be appreciated. Is this information available in the operators/owners manual????<br /><br />thanks
Paul Moir
Re: 1957 wiring diagram
You really ought to get a manual for the engine even just for basic maintance. They pay for themselfs quickly. Personally, I perfer the Seloc aftermarket manual, or an OEM manual for that engine. The Seloc ones are available here. OEM ones often come up on Ebay, or you can buy a reprint from kencook.com.<br /><br />The wire for the choke (should be the small red one) just needs to be switched to +12v to activate it. It is grounded through the engine block. The big red wire goes to the post on the starter, and the big black wire goes to the bottom stud on the starter bracket. The solenoid (in the box) has two small posts. One post should go to the start key (+12v to activate starter), and the other goes into the engine through a small back wire. Inside the engine, this connects to the base of the vaccum cutout switch (the device connected by a tube to the intake manifold). This gets grounded by the mercury switch, which should also be tied to the base of the vaccum cutout switch. The purpose of the mercury switch is to only ground the solenoid, and so let you start the engine, when the throttle is at or below the start position.<br /><br />PS - Grounding the post on the top of the vaccum cutout switch should stop the engine. Watch out for this post - it will bite when the engine is running.<br /><br />I hope all that helps!
