1957 Evinrude Fastwin 18hp carb problems
CESARP35
Hey guys, i recently purchased a 1957 Evinrude Fastwin motor model 15020 from an elderly gentle man who stated that the motor had been stored in his garage for the last 25 years or so, it looked to be in pristine condition, i brought it home and hooked it up to the gas tank out of curiosity and darn thing fired up however impeller was not pumping water, so i turn it off, i decided to purchase a lower unit gear seal kit, carb kit and water pump kit, i replaced and rebuilt the mentioned items, i went to start the motor and it started and ran for about 30 seconds the water pump and lower seals worked great, however it now starts and and dies after a few seconds, theirs seems to be a lot of gas coming out from the main carb chamber as if it's flooding, as i prime the primer bulb i can see gas spilling out of the carb, i'm going crazy as i took the carb apart 3 times now to see if there's anything i missed, float was adjusted level to carb housing and everything seems fine, seems like float is not closing all the way for some reason, any help is greatly appreciated guys!!!
Joe Reeves
Sitting for that length of time..... At a minimum, the carburetor needs cleaning thoroughly and rebuilding, after which, adjust it as follows.
(Carburetor Adjustments - Two Adjustable N/Vs)
(J. Reeves)
Initial settings are: Bottom high speed = seat gently, then open 1 turn out. Top slow speed = seat gently, then open 1-1/2 turns.
Setting the high and low needle valves properly:
NOTE: For engines that DO NOT have a shift selection, obviously there is no NEUTRAL position. Simply lower the rpms to the lowest setting to obtain the low speed needle valve adjustment.
(High Speed) Start engine (it will run pretty rough), shift into forward gear, take up to full throttle. In segments of 1/8 turn, waiting for the engine to respond between turns, start turning in the bottom high speed needle valve. You'll reach a point whereas the engine will either start to die out or spit back (sounds like a mild backfire). At that point, back out the needle valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest setting.
(Low Speed) Slow the engine down to where it just stays running. Shift into neutral. Again in segments of 1/8 turns, start to turn the top needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running. Eventually you'll hit the point where the engine wants to die out or it will spit back. Again, at that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
When you have finished the above adjustments, you will have no reason `to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
CESARP35
Hey Joe Reeves thanks for the info , the carb was incredibly very cleaned as if all gas was drained before storing, i did however do a complete cleaning of the carb just to have a piece of mind,, i took all parts apart and left it in carb cleaning solution over night, i cleaned and air blew all ports, and put back together as instructed, i've tried adjusting the needle valves when the engine turns on but turns off just as i turn the low and high needle adjustments, whats got me baffled is the out pouring of the gas in carb as if the float is not closing completely causing it to flood, i wonder if the gasket is somehow touching the float slightly and not allowing it to fully close? I just don't know what else could be the problem. Any more suggestions are appreciated. Thanks
CESARP35
Yeah Crosby i also posted it on that website hoping someone might have a different opinion that can help me with this problem. Thanks
Honorary Supreme Mariner
Have you looked at the ignition coils , yes or no ?---That has to do with stalling problem.----And yes you need to look at the float and float valve to stop fuel from leaking out of the carburetor.----Nozzle gasket is in place.---Any pictures of the 2 carburetor gaskets ?
CESARP35
Racerone i will definitely do the coils next, once i get the carb issue taken care of. Thanks!!
Crosbyman
just kidding ...
flooding carbs are just like toilet bowls
if it is flooding, the inlet needle is not doing it's job or the carb float is snagging
on something preventing the needle from being pushed UP to close up the gaz flow
if it starts.... open up the tank cap to drop the pressure pushing fuel up to the fish bowl & carb see if the engine will run a bit longer with the available fuel in the carb
you did install the boss gasket #58
CESARP35
Yeah Crosbyman i did install that gasket, i will give the loosing gas tank cap a try tomorrow when i get off work and see what happens, i'm going to also check out the needle and seat to see if it's closing all the way, thanks for your input i really appreciate it!
Crosbyman
if you flip that carb upside down you should not be able to blow air in the fuel inlet
btw I hope you have the correct inlet needle for that carb..some seem to be shorter than others
CESARP35
[h=4]I used this carb kit witch seems to be the correct one for the year Evinrude/Johnson Carb Repair Kit #439071, i kept the original needle just in case, i will compare the size later on today when i get home from work, i suspect it's got to be a valve and needle seat problem i'm going to fiddle with it to see if the needle is closing all the way, and i will also try blowing in the inlet to see if it's leaking. Thanks for your input it's appreciate. !![/h]
CESARP35
Well guys her's a video link to the running motor, it feels good to finally have it running, thanks to all who helped me with ideas and suggestions on this forum, it turned out to be the OG coils that were toasted and not the carb, and after replacing coils, condenser, points, plugs and wires this is how it turned out. Thanks again guys!!!
https://youtu.be/Hm4EFGUo7_Q
