Superbigstevie
Thread starter- Joined
- May 24, 2003
- 4
I have been gifted a 1956 15hp Johnson model FD10L. I think I need to overhaul the ignition system? I have rebuilt the carb and two line tank it will now start on the second pull! It has 85# on the top cylinder and 87# on the bottom. With the exception of the prop and the lower end oil every part is original. Even the pull rope! I think it is under 300 hours.<br /><br />Question #1 After about 1/2 hour of operation it will not restart. Put in new plugs (J6C) it fires right up. Is the spark week? What parts do I need? Where to find? How much?<br /><br />Question #2 How do I hook up a shop tachometer? What is the max RPM? I have read 4000-5500. <br /> <br />Question #3 What is the aprox value of the outboard?<br /><br />Question #4 What do I need to change the impeller? Cost? Source?<br /><br />Thanks
