jonboatman
Thread starter- Joined
- Mar 8, 2003
- 7
Hello all,<br />I am new to the boating thing. I know little more than how to start an outboard and get going. I have good mechanical knowlege about cars, so the basic engine mechanics is no problem.<br /><br />I bought my grandpa's boat from my grandma. My grandpa passed away 9 years ago and the motor hasen't been ran since. The serial # is 10012 08643. I went to pull the rope and the motor was seized up. I then took the head off and sprayed some penetrant and got the motor to turn freely. I was a little afraid to just put the head back on and hit the lake, so I went ahead and took the motor apart. I have a few ?'s if you folks don't mind to help.<br /><br />The rod bearings are needle bearings and they seemed a little loose, not terribly, but if you grabbed the rod they would twist a little. Is that OK?<br /><br />I called a local outboard shop, and they said parts were unavailable. Is that true? He also said that the old evinrudes had to be ran at a 16:1 mix because of the bushing in the block needing a lot of oil. Is that right?<br /><br />What kind of gasket maker do you use on the block halfs and the block to lower unit surfaces?<br /><br />Also is the typical 15hp carb swap that I read about possible on this unit? <br /><br />Is shaving the head to gain a little compression a good way to get a little more power?<br /><br />All I have ever worked on is cars, so a two stroke engine is a new game to me. Is there any other way to gain some power without losing reliabity?<br /><br />One last thing. While the motor is off, is there anything else that should be looked at or replaced?<br /><br />Thanks for any help.
