jroberts24
Thread starter- Joined
- Mar 14, 2003
- 26
This is in reference to the topic I posted two days ago. I really appreciate all of the many people that responded to the topic. I have narrowed the carb problem to a problem with the gas going from the sediment bowl to the carb bowl. Everything else is good. The motor will crank right away, but dies after the gas in the bowl is gone. Leave it alone for a few seconds, and it will crank again. If you keep trying to crank it, it won't crank. The tank is holding good pressure and there is no air leaks in the fuel line/connections or the carb. The float and needle valve is alsow working good. So, that leaves the port from the sediment bowl to the carb bowl. Can the little rock looking filter clog? It is held on by a screw. Will it mess anything up if I take it off and clean it? Any input would be much appreciated.<br /><br />Thanks,<br /><br />jroberts
