1955 johnson powerhead on a 1955 evinrude?
hitace
i seen a 1955 johnson 10 HP power head on ebay and was wondering if it would work on my 1955 7.5 HP evinrude fleettwin?thanks
Texasmark
Re: 1955 johnson powerhead on a 1955 evinrude?
I'd bet Tasha's daddy knows the answer to this. Probably will. As I recall over the years, I have seen blue/green engines on boats from time to time.
My response will bump it up so that he might catch it.
Mark
hitace
ok thanks i really hope so.but its a little bit different in HP.so i am not sure.they look pretty much the same.
steelespike
I don't think it will work.While they are listed in the same section in my old after market service manual.It shows a different blowup for the power heads and also for the leg/gearcase.
The 10 is 16.60 cu. in. the 7.5 is 12.40. As I recall the legs appear distinctly different as well.
Chinewalker
It will not work. The 10hp will bolt up to a 15hp leg of the same year, though...
- Scott
tashasdaddy
Scott got here first. green and blue mix, but has the be the right ones.
