1955 Johnson 10hp fuel conversion
cgaddis
Hey guys I was given this motor from a friend. I replaced the water pump, rebuilt carb, replaced coils, and points. After some research and no old school tank I decided to do the single line conversion. I bought a brand new Johnson pulse vaccim pump, and removed the old top bypass cover and made a new one from aluminum and mounted pump directly to the bypass cover. The motor cranks no problem, the only thing I'm not sure of is the old nipple from the crank case. I pit a vaccum cap over it with a clamp but I'm curious if I cap it off would that build pressure in the crank case or would that pressure now be coming out of the port hole in the bypass cover to my pump now. If so I'm thinking of brazing the old nipple up to just not deal with the clamp and vaccum cap. I'm interested in your input?
F_R
Honorary Supreme Mariner
As long as it is capped or otherwise plugged, it is good to go. A lot of people use a short section of hose with a plug (shear pin?) clamped in it.
cgaddis
Yea I actually just took it out on the lake today and it was a success. Thanks for the fast reply
