biloxiriver
Thread starter- Joined
- Aug 20, 2002
- 256
I have read with interest, some of the discussion on this topic but am still a bit confused. My 1955 7.5 Evinrude says to mix 30 wt oil at 1 qt to 5 gallons. That is what I have ran in it for the last several years and it runs fine at top end but doesn't idle smoothe. And, since it does smoke a bit at start up, I would like to know:<br />1. Can I, or should I, change to modern 2-cylce oil?<br />2. What ratio should I use using modern TCW3 2-cycle oils?<br />3. Could the oil be the idle problem? <br /><br />Can anyone help? Thanks much.
