codyjoelsmith
Thread starter- Joined
- Nov 11, 2016
- 4
I cant get this motor to idle. No matter where i set the jets. Nothing seems to help. It runs pretty good at WOT but once you back off to the start position it dies. I have watched videos of these motors chugging along all the way at the slow position. Mine wont get close to that. I rebuilt this motor from the prop up. It has good compression at 80 psi and crankcase pressure seems to be good. No blow back. I rebuilt the entire carb and recently took the carb back off and cleaned again, and checked the reeves while it was off. Everything looks good. Low speed jet and passages are clear. I also reset the points and that did get rid of some of the bogging at wot but did not help it idle and the RPMs still fluctuate a little at WOT. It has good spark on both plugs but i have not done a spark gap test yet. The only thing i found weird is that one of the plugs after running several times still looks new with no carbon But is wet with gas when i pulled it out. The other plug is black. I remind you that both plugs are sparking good though and if you pull either plug wire off while its running it dies. Im starting to wonder if i missed a crack in the block and it may be getting water into a cylinder. If anyone has any ideas on how to check for water in the cylinder or something else that may be wrong, please let me know. I also would like to know if anyone knows how to do a link and sink on this motor. Thanks, Cody.
