1953 johnson 10hp
Jawskidding
Just bought a boat with a qd 14 on it, no pressurized fuel tank. I'm going to install a fuel pump but can't find the replacement powerhead assembly cover from a newer one (60'S model with fuel pump). I saw some DIY videos but none mentioned drilling a hole and threading a barb connector straight to cover... is this feasible? Most recommended a 60'S model cover plate or piece of flat aluminium with hole to attach fuel pump but that seems like extra/ unnecessary work. Please advise, all thoughts welcome
Crosbyman
No Title
done both plate and threaded nipple on a cover plate .... just plug the AIR nipple behind the carb and either solution works
Jawskidding
Thanks Crosby
Jawskidding
Hey crosby, did I see on another forum that you got a PDF of the manual? If so, possible to forward it? I threaded the barb on the assembly cover, worked like a charm.
