k31shooter
Thread starter- Joined
- Mar 23, 2010
- 9
Hey first time poster, BUT i have a problem and i feel like you can help. I inherited a Chris Craft Challenger, and it hasn't run in quite a few years. A few weeks ago i decided to pull her out and give her a pull. The results surprised me when she kicked over on the first pull. Now for the PROBLEM! After rebuilding the carb., lower unit, water pump,and also replaced the exhaust manifold gaskets I am having an extreme overheating problem. The water system is free and I can blow air through it when the manifold isn't on. I have taken the head off and inspected the gasket and i am sure that the coolant holes are clear of obstructions. When I run the engine, steam rolls off the exhaust manifold and water visibly and audibly sizzles from the face of the manifold. I have inspected and re-inspected and also tore the engine down and rebuilt all critical components and the results are still the same. I am assuming that the manifold having a temperature range of 200-300 degrees F. is a horrible and i am also assuming that water is not making it through the exhaust manifold. I have exhausted my knowledge and am screaming UNCLE! Someone PLEASE HELP!!
Thanks for your time
