Hi All,
New to the forum here but have found many of the discussions to be extremely helpful. I'm in the process of restoring a 1947 (I think) Johnson Seahorse, model PO15, and can't seem to figure out how (or if its possible) to connect a stop button/kill switch to the existing wiring. The tiller handle was removed to mount onto a 1956 Penn Yan Swift with a center mount steering (cable/pulley system) and as a result, any stop button at the end of the tiller no longer exists. There does appear to be a single wire coming from below the magneto, which presumably was previously run through the end of the tiller to the stop button. I've confirmed this does short out the system when touched to another part of the motor so I'm hopeful there's just some adapter that was used to connect to the end of the wire itself as the stop button.
Does anyone have any experience installing a stop button on a motor this old? Most newer kill switches seem to have to wire leads, which doesn't seem to fit the current setup (haven't taken the magneto off to see what's inside the housing) since I only see the one wire coming from under the magneto.
Any help would be greatly appreciated!
