18hp two stroke no power under load
elitl
The engine runs great with hose hooked up but when you put it in the water it has no power. I replaced the spark plugs and still there is no power. The engine starts on the first pull every time.
Please help?
It is a M18 C tohatsu engine.
TOHATSU GURU
Re: 18hp two stroke no power under load
Check compression, fire and oddly enough, the gear oil.
TOHATSU GURU
If you do not have any metal fragments in the gearoil then I would look at the fuel system as the most likely source of your problem.
