18hp on 16ft fiberglass Quachita ????
fish2day
I have a 16ft fiberglass Quachita boat that came with a 50hp evinrude and steering. I have removed the 50hp and steering and I have an 18hp johnson tiller handle I want to use.
Is this engine too small ?? Will it push the boat along ok ??? Opinions appreciated.
Bob_VT
Re: 18hp on 16ft fiberglass Quachita ????
The 18 will move the boat........ getting up on plane will be questionable but, a great size for fishing. Try it ;)
JB
Please do not post the same question in multiple forums. It is annoying to helpers to answer it in one forum and then find the same question again.
steelespike
Really need more info.What is a Quachita? Weight.shape,deep V, flat bottom round bottom.
Full dress with floors,livewell built in tank etc etc.Also what kind of load?
An 18 on a boat its intended for could produce about 27 mph.
It could do ok on heavier boats if setup right.
fish2day
Its a open bow type bass boat with only two pedistal seats and one small built in live well. Other than that it is empty, but fiberglass, semi v bottom. I think they called them a bathtube style bass boat. 1974 model 16ft. Just wondering if anyone had tried a similar setup. Thanks
Home Cookin'
a friend had one back in the 70's. I think he had an 85 on it. Fairly heavy boat. An 18 will push it, but not very fast. Being underpowered canbe dangerous, too.
lncoop
Fish2day, I know exactly what your Ouachita looks like. You won't be winning any races with an 18, but you'll be fine.
Home Cookin'
there's a reason it came with a 50. replacing it with a motor that is too small, just because you have it, might not be a wise choice in the long run, when you find you aren't satisfied with it being so limited. You may wear out the 18 if you have to run it wide open against a relatively big load all the time. and there can be a safety issue.
A guy near me keeps a sailboat on a mooring ball; he lives on the water a short distance away. He got one of those "free" generic old 16' bowriders and stuck a 9.5 on it, so he has less invested than a new dinghy/tender would cost, and more size. But his rig isn't good for much of anything else.
So to answer your question, we'd need to know your intended use. For general use, I'd opine it's too small. And I'm not one to seek top speed or favor overpowering boats; we used to get along fine with a lot less HP than you typically see today.
