Re: 18hp mercury problems starting
The first thing I would do is buy a manual for your motor, available on the web and at this site or from your Merc dealer for about $20.<br /><br />Does the motor run OK above idle? <br /><br />If it had not been used for a long time before you bought it, the carbs are probably gummed up from old fuel. I would systematically work through the fuel system from tank to carbs, strip and clean the carbs (lot's of info on how to do this on this site). <br /><br />I would also check compression and ignition and make sure it is all to spec.(again lot's of info on this site).<br /><br />This should fix the problem.
