geekomatic
- Feb 12, 2005
- 136
I've rebuilt the carb with a new float as well.New points (checked the gap several times),new coils,new condensors. I actually manager to get it all back together.Plugs get great spark.The gas mixture is right,and the it's pumping gas like crazy.It will crank and run for appr. 5-15 seconds and then die.I started fiddling with the high and low speed needle valves just to see if I could get it to even out and idle for awhile.It always dies.There is gas puking out of the carb intake where the choke butterfly is located.After it starts running, the leaking appears to stop. New electric choke works like a charm, by the way.<br />The needle valves look brand new and I did replace the packing on both.I adjusted the new float as best I could.One screwy thing:The low-speed needle valve packing nut was missing when I got the motor.Impossible to find a replacement, so I went to ACE and got the closest thing possible and screwed it in there. Not the best fit! Bad Idea? <br />I can't seem to find any proper starting instructions for the motor.They were on a printed sheet on the inside of the cowl, but they've disintegrated to the point where I can no longer read them.Is there a standard starting procedure?<br />On a side note: I also replaced the lower unit fluid when I swapped the impeller.It pumps water fine.I get a nice spray when it's running.At this point, I'm just glad to get the thing back together, but I would love to put it to work.
