18hp Evinrude year and other stuff????
I just traded my old quad for a boat and it has a Evinrude outboard on it and i have the serial number 18502s-e10180 any info about it would help like what gas mixture, im not sure if it runs yet so for that where i can order parts, plugs, i know i need a prop and all that good stuff so any info could help thank you
Ross72
Re: 18hp Evinrude year and other stuff????
It's a 1965, check marineengine.com for a parts list and most parts should be available here at iboats.
steelespike
Check the top secret file at the top of the page "waking a sleeping outboard".
First thing to check is compression.100 psi is concidered ideal minimum for hand cranked,within 10% between cylinders.It likely needs coils.Routine ignition,fuel and cooling parts are available right here at iboats.
samo_ott
100 psi? wow, that's high, I don't think any of my 18's are that high. It'll run fine with 80 psi a side but it wont have as good a top speed than if it was higher. And I have the parts manual for the 18502 if you want it, PM me your email address and request if so.
