18'concept marine center console
Vitamin Sea
[h=2]In need of info of 1987-89 18'concept marine center console[/h] [COLOR=#6A6A6A !important]Yesterday, 08:39 PM[/COLOR]
I need info on
18' center console.
so far I have found that Concept Marine and Concepts Boats are not related at all
Concept marine built boats form approx 1987 to 1990
center consoles
18-27 feet
Other than that thats all i have
I hoping someone on the forum may have some second hand info that they can share about these vessels
hp limit, weight, and any other specs
I have inherited the 18 center console a would like some info I want to re-power the old 1989 70 Johnson sems under powered I have New old stock 1993 115 Mercury ELPTO I picked up thats like new but hasnt been run for a few years
any help will be appreciated
I plan to post a few pics
greg
below is a picture of a 1987 26 that I searched but is all I have found
Vitamin Sea
I need info on
18' center console.
center consoles
18-27 feet
greg
Need info on this boat engine size tank capacities ect
GA_Boater
What are the 3 first letters of the HIN?
The pics didn't make the trip.
GA_Boater
Decoding HIN FRI18002K889 after using FRI18002K889 yields;
HIN Search results:
Success! FRI18002K889 is of the standard HIN type called Current-Format HIN. If you are buying this boat/craft then you should get the Boat-Alert History for 9.99$ and consider Boat Insurance from the BoatU.S. Program.​
[h=1]FRI HIN Decoder[/h] Our HULL ID Decoder breaks down the Hull identification number into the following information:
The HIN or CIN you have entered meets the Current-Format HIN format. It might also be a type that contains the country code and thus the boat comes from USA or Other . The serial number of the HIN is 18002 and is set by the boat builder. This boat or vessel has a Certification Date of (8) and a Model Year of 1989 with month of build (November) based on the formatting of your hull_identification_number (HIN) .​
The manufacturer identification code (MIC) of your craft identification number (CIN or HIN) is FRI. This MIC (FRI) stands for the company name Concept Marine Corp which is currently Out of Business. This boat manufacturer has other company names (FRI sometimes goes by these name(s) Concept Holding Corp, Reactive Power Boats, Frost Marine/see (koh), or .​
This company (Concept Marine Corp) is owned by Eddie Cothron and is located at 12855 DANIELS DR in CLEARWATER state of FL. It manufactured this vessel and placed you HIN or CIN on the hull. The Parent Company for this boat maker is (). Concept Marine Corp has started making boats, yachts and other watercraft as of 04/12/1982 0:00 and went out of business on (10/30/1990 12:00:00 AM) in the following country: .​
Make sure to compare the date of boat manufacturing with the dates in which the company was actually in business.​
The US Coast guard provides this comment about this watercraft manufacturer: Old Address Prior To 5/85: 1521 Ne 10th St, Homestead Fl 102186 Formerly:andy Frost/rt 1 Box 55b Islamorada. See (koh) -> Attorney (305)664-4675 (fri) Attorney -> (305)949-5009 3/89 New Address. Inactive Per Cg-5093 901030/mso Tam..​
More details at the US Coast Guard.
Isn't a USCG plate attached somewhere inside the hull with the max horsepower, weight and passenger ratings? If the fuel tank is under the deck, are any access hatches in the deck?
Vitamin Sea
No USCG plate located anywhere.Also tanks is located in the floor and I have access to it . The capacities plate cant be seen . Removing console next step if all else fails.
Thanks for that Info
I managed to find similar info.
but no technical info at all
pretty rare vessell I see very short production run from the builder explains the lack of info
