185 johnson vro overheating
seaker
I have a 1985 185 johnson vro. When running at high speed after about 3 to 5 miles alarm goes off on the left bank boat runs great. I replaced sending unit thermostat and bypass springs and rubber parts . now I removed the lower end and all looks good . Next I put a hose to the water tube to the power head and it is leaking at the top. Is this a overflow for when the thermostast is closed or is the seal bad ? I am having problems getting the bolts out to remove the power head to replace the rubber gromet at the top of the water tube . Part is only 5.00 but if you can't get to it that does not matter much . any advise. ok now i have broke the bolts off and the power head won't move
