18 HP Tohatsu idles bad when cold
jmill15
My 18hp tohatsu motor doesn't idle very well when it is cold. It will shut off 7 or 8 times before it ever warms up and runs smooth. The choke will not even keep it running. I think it could be in the fuel filter or something but i am not much on boat motors. Any help would be greatly appreciated. Thanks
TOHATSU GURU
Re: 18 HP Tohatsu idles bad when cold
Clean the carb and then reset the adjustments.
jmill15
Not sure i understand what tstat is. Please verify that for me. Thanks
TGuy
tstat=thermostat
John_S
I would focus on fuel system, too rich, too lean. I would expect a stuck open thermostat would also cause too cold running conditions, ie it would never warm-up. A thorough carb cleaning and readjustment would be the first job to tackle.
ericab
I purchased a new 18hp Nissan (Same Thing) last year. By the end of the summer it would not idle, but would run once heated up. Took it to the dealer and they dianosed it as the Bi-Starter. The Bi-Starter is the small capsule looking devise with a couple of wires coming from it. It essentially perfoms the same function as a choke. It allows the engine to idle when cold.
Hope this helps. I had purchased the maintenance manual, and the Bi-Starter is not discussed.
I have had my new engine out twice this season and on the second trip after stopping for lunch the engine now will only run at idle speed......go figure
Very unhappy with this engine.........
diver1@concast.net
TOHATSU GURU
Clean the carburetor. After a year of use you probably have a dirty carb. From now on run the gas out of the engine after every use and only use fuel less than 2 months old.
