18 HP Tohatsu carb adjustments
savage
Does anyone know the proceedure for adjusting the idle mixture screw on a 18HP Tohatsu? Should I adjust the base idle speed in gear and at what rpm? Thanks in advance.....Savage
phatmanmike
Re: 18 HP Tohatsu carb adjustments
it should alway be done, in gear, in the water at idle.(not on the muffs, actually IN THE WATER) i dont know for sure what your idle speed should be though, im thinking about maybe 700 rpms sounds good
TOHATSU GURU
Set the screw at 1 3/4 and then adjust from there.
