18 hp question
OMCFREAK
g'day my 1967 evinrdue 18 is playing up on me. i bought the engine and had to re seal the crank case as it was leaking fuel all over the place. so went i try it out on my boat for half and hour i get back to the ramp and take the cover off and there is a splatter mark on the inside of the cowl and it is fuel. the splatter mark is opposite where it was leaking before. and another thing is it normal with these engines that there is a fine layer of fuel in the bottom of the cowl at the back? the fuel is like the thickness of say, melted butter.<br /><br />Thanks
geofthro
Re: 18 hp question
Melted butter! Doesnt sound to good mate! Sounds like a leak back at the carbs and water is mixing in with either the oil or fuel which of course isnt a healthy thing. Sounds like new gaskets all round to me and then make sure everthing is torque to spec' What did you reseal the crank case with?
OMCFREAK
Re: 18 hp question
i used a sealer called Form-A-gasket. my dad used to be an outboard mechanic and he has a old tin of the propper stuff lying around in his shed is form a gasket much differnt?
geofthro
Re: 18 hp question
Cant say ive heard of it! But i can say in the past i have being advised by many on this site to use a product by the name of gel-seal! Which has worked for me! Keep your eye open for other posters! Alot of knowledgeable people belong to this site and someone should get back to you about this a little more concerning you leak! You an oz or kiwi?
OMCFREAK
Re: 18 hp question
Australian mate, from Newcastle. very good fishing there now since BHP closed down
alcan
Re: 18 hp question
Hi OMCfreak<br />Here in the U.S. Form-a-gasket is a Permatex product. While it is a good product used in the correct application, it is not the right stuff for sealing crank cases. Gel-seal is good stuff too and is recomended for most modern OMC crank cases. On models of your vintage sealer 1000 is called for. All of these products have equivlents sold under different names. I can see this might get confusing. You may need some one from down under to help steer you to the correct product in your area.
geofthro
Re: 18 hp question
"O AUSTRALIAN" Figures! Leaking fuel and oil everywhere! Just kidding! welcome to iboats mate! :)
Paul Moir
Re: 18 hp question
The proper sealer is called '1000 Sealer' or OMC Adhesive sealant 'M', and it should be available from the dealer. Gel seal isn't for crankcases with spagetti seals (to the best of my knowlege anyway). A good subsitute is "Three Bond 1104" if you can find it, or 3M's "Scotch-Grip Rubber & Gasket Adhesive 847". <br /><br />Permatex Form-A-Gasket won't work. I should know - I tried it once. Neither will any sort of RTV Silicone.<br /><br />I have had good luck with Permatex MotoSeal Grey, which is made for the purpose. But the engine's I've tried it on have only seen a year's service so far so consider it a last resort. Still, I find it applies easily and isn't bad to clean up so I'm hoping I can use it in the future.<br /><br />Hope this helps!<br /><br />EDIT: Alcan got his post in while I was typing. Don't take mine as contradictory to his at all. Pardon, alcan!
OMCFREAK
Re: 18 hp question
yes thinks for the help. lucky i can get acess to the proper stuff my dad has a tin of that stuff
