18 HP Johnson wont go in foward
EEEkingofgrapes
Finally got my 1965 18 HP Johnson cranked today. Second time trying to start it, got it started this time, but it would only go in reverse. The gear shifter would shift into what should be foward, but the boat wouldnt go foward. Reverse and neutral both worked, but no foward...any advice?
Mod2
Re: 18 HP Johnson wont go in foward
Moving to Johnson/Evinrude Troubles/Repair forum.
wikelam
does it run off of a control box. if so it might be out of adjustment.
Skyhigh
It sounds like you need to check your forward gear….<br /><br />To check your forward gear, you have to remove the bearing carrier.<br /><br />By the way were there any metal particles in the lower unit when u drained it.
