Re: 18 hp. evinrude fouls bottom plug
compression is 75 on the bottom and 85 on top.not as good as i would like but it should still run evenly.plugs are champion j6c.when i had it running in a barrel the other day,i took the "in" hose off the fuel pump to see how much suction it had.i couldn't feel any,but it keeps the sediment bowl full.it is a evinrude 18hp fastwin.numbers on "freeze plug" are 15032on top and below that are 20533.any more info would be great,but i sure appreciate what you guys have already said,thanks.
