18 HORSE EVINRUDE
CB31
I HAVE AN OLD 18 HORSE EVINRUDE , MY PROBLEM IS WHEN I OPEN IT UP I LOSE HORSE POWER. DOESN'T SEAM RUN LIKE AN 18
JB
Re: 18 HORSE EVINRUDE
Howdy CB.<br /><br />Please don't shout (ALL CAPS!!).<br /><br />You are running on one cylinder.<br /><br />Read some of the dozens of posts about loss of power.<br /><br />Good luck. :)
CB31
Thanks for the 411, could some one please tell me how to fix the problem
oldboat1
The symptom you describe could have a number of causes. Start with the simple things first. Check your fuel lines from the tank. Make sure the vent is fully open and that the lines are not crimped anywhere. If you have a two-line system, there may be a problem with the pressure tank.<br /><br />next in line would be fuel pump and carburetor. If failure is only at high speed, and probably one cylinder, it's most likely a dirty or partially clogged jet in the carb.<br /><br />But these are broad guesses. You need to supply the year/model number of your motor so folks can better assist.
