17p or 15p for 1996 Force 40 hp
1973Chieftain
My '96 Force 40 was running right about 4900 rpms with a 10x17 prop, and although my hole shot was not outstanding, I was getting 31 mph by my gps. This past time out I hit a rock I think which really chewed up my prop, and my only spare was a 11.25x10 that came with the motor. Now unless the diameter effects things a huge bit, im guessing that's way under pitched for my light 15' tin boat. My goal is top speed, the only thing besides cruising I will be doing is casually pulling a tube on hot summer days. Since 4900 is right at the low end of the employees range, 5200 being the high end I beleive, would I benefit from stepping down to a 15 pitch? Would that effect my top speed? Thanks for the advice, im very much a prop noob! (And I have three engines im setting up :( )
steelespike
Re: 17p or 15p for 1996 Force 40 hp
If that has through hub exhaust it is a Merc leg and gives you more choice on props.
a 16 is the highest listed under Force while a 17 is listed under merc.A merc 15" is the same number as the Force.
again assuming the merc leg.
If a 15" prop gets you 5300 with about 10% slip your speed would be about 33.and the 15 should do better with a load or water sports.
As far as your 10" as pitch goes down diameter goes up. You can get around with a 10" but will have to be very careful to stay within
the rpm range 4750-5250.
Your motor height can affect performance as well.The anti vent plate(just above the prop) should be about even with the bottom of the transom.
1973Chieftain
As always steelespike, you are the man! Thanks! It is a 13 tooth spline with through hub exhaust. Iboats only has up to a 16p but numbers of other places list 17p props for her. The engine is mounted rather high at 2" above the keel, I messed up when I rebuilt the transom.. a project for next winter. So you would think going to the higher end of the rpm range would be beneficial? Thanks!
1973Chieftain
Update: I bought a mercury 15p, and am getting 33 mph (gps) @ about 5150 rpms.... thanks for the advice steelespike!
steelespike
Wow! Sometimes you get lucky. Thanks for the feedback its bound to help others.
