matt88
- Mar 17, 2009
- 160
I have a 16ft x 6 ft flat bottom jon boat with the high sides and have been running it with a 30hp tohatsu. It runs fine as is with two or three people and gear it will run about 22-25mph. I have just acquired a 1956 30hp two stroke evinrude and had a hair brained idea of running both engines on the jon boat. Just wondering if anyone has had any experience with a similar setup. Would I have to have the same pitched props on both motors? I have seen twin engine setups with bigger motors on glass boats but Im not sure if twin 30hp engines would be worth the hassle. If it would turn my 25mph boat into a 40-50mph boat it might be worth it to me but Im not sure what to expect. As for the transom it already has reinforcement brackets running from the transom to the floor and if I did put the other 30hp on I would add even more reinforcements so that shouldnt be an issue. Also was wondering if I would need a left handed prop for one of the engines? And if so is it possible to change one of them to a left handed drive? Like I said this is probably more of a hassle than what its worth but I thought I would ask to see if anyone had tried it. thanks
