Re: 160 thermostat
Modern motors run well above 190 deg. If yours runs at a constant 170 even with a 160 t-stat I'm sure that everything will be ok. Your guage could well be off by that much. Consistancy is the key.<br /><br />The only reason that boats have 160 deg stats is to keep salt from plating out in the engine, otherwise 180 deg would be an ideal temperature for combustion efficiency.
