Bill Foote
- May 27, 2009
- 15
I have had my ss for a while now and mounted on the back is a 70hp johnson 1988 model I also have a 19p prop. I have always thought that this motor was a fuel hog but having nothing to directly compare it to I never lost sleep on the issue. The engine runs perfect otherwise, starts easily, PLENTY of power and idles well also...
Then, my friend bought the exact same boat/motor combination. He has a 16' ss with a 1986 70hp johnson also a very good running motor. The first weekend after he bought his boat we went camping with the boats. We both ran the same exact distances side by side the whole weekend (about 14miles total). At the end of the trip as we were flushing our motors out I noticed his 6 gal fuel tank had about 2.5-3 gallons still in it while mine was nearly bone dry. We have the exact same fuel tanks and both were full at the beginning of the trip. Every thing is the same even oil ratio.
So, I am sure some of you are familiar with these motors any Ideas for this problem??
Imediatley I suspect that at some point someone cleaned the carbs in my motor with an instrument that removed metal from the jets making them larger. I am also suspicious of the primer solenoid, is it possible for it to leak fuel into the carb throats during normal engine operation(obviously the manual prime lever is not engaged)? Are "jet kits" available for outboards as they are commonly for motorcycles which basically include larger jets?
Thanks in advance
Thanks in advance
