15HP Evinrude Will not start
Andy85
I have a 83 15 HP Evinrude that will not run. When I put it on the water and pull the rope it will start, sounds ok, for about 3-5 seconds then die. After it dies it will not restart no matter what I try until I pull it out of the water and try again another day only to have it run for 3-5 seconds then die. It only takes 2-3 pulls to start.
No amount of starting fluid makes a difference. Today I tried setting the unit 2.5 turns rich and again the same thing 3 seconds and it dies. I let it sit about 15 min while I checked around on the internet for options and at the end it would not start. I did end up with an oil slick under the boat. I have also tried various other settings going very lean, "just right" and rich. NOTHING
Today I took off the coils and pack to inspect for damage expecting a spark issue. Everything looked ok and the coils were OK via multi-meter. I then reassembled and created a DIY spark tester; both coils have a very nice spark (rather impressed tbh)
The unit did end-up with a broken swivel bracket due to my noviceness as such the power head was removed this winter to have that welded.
I'm at a loss and am about to toss it in the weeds, I could use any suggestions that might get this up and running. I'm am hoping to put this on the water for the 4th
-Andy
jakedaawg
Welcome.
Try a fuel sample first. Drain some of the fuel into a clear can and look for phase separation.
A compression test would be in order also.
Andy85
Hi Jake,
Thanks for the welcome. I ran your recommended tests.
Fuel looks good, no water. It was fresh originated from last year. have about 3 gal left.
compression test Results
78# cyl1
80# cyl2
In my mind that's low but considering the age... It should at least start and run more than 3 seconds.
I also believe my fuel pump is ok. I replaced the fuel line going from pump to carb. When removed I left the carb side disconnected and tested to see if gas would come out. It does.
Thanks!
AlTn
spark test..is it jumping a 7/16" open air gap?..until you verify it will do that, don't consider it a non ignition problem..if it will do this..move onto the fuel end of things as your compression numbers are adequate. Try googling "Leeroy's Ramblings.. 9.9/15 hp. Johnson/Evinrude maintenance and repair" he'll have info that will help you. Did this motor ever run properly for you?...
Andy85
Hi AITn,
It will jump the 7/16 gap. almost 1/2" (i didnt try futher) both coils
I just tried to start it on muffs and i got a few puffs then nothing. I retested the spark again just to make sure and still good spark.
I have been looking at Leeroy's Ramblings for a while...
Motor ran Excellent Last year & the year before. Beyond that I do not have history but overall it has been ok but a bit hard to start from what I have heard. For me after fixing an air leak when I first got it it has typically been difficult in the spring but otherwise after the first start great at starting.
gm280
Have you mixed up some 50:1 fuel oil mixture and tried squirting a little into the carb and try. And when you are starting this engine, is you primer bulb getting firm. Stop using starter fluid if you are doing that. That is a huge no no... :nono: Starter fluid washes all oils out of the bearings and during start up that leaves them high and dry. Use a 50:1 mixture in a little squirt bottle instead. If it will fire with a 50:1 mixture, and I see no reason it shouldn't if your spark is indeed great like you stated, then look at installing a carb kit... If by chance it doesn't even try to fire, have you sheared the key way in the flywheel. If that key way is even a little off, the timing will be out...hence no fire at the correct time...
kawaboy-zx11
its sure sounds like a dirty carb issue to me, did you put stabil in the gas before storing it? i have an old yamaha 3 wheeler that if i do not put stabil in the gas it will not start after the 3 month sit over the winter without pulling the carb off and cleaning it....some carbs are just real picky like that,
AlTn
here's what I'd suggest...since you determined that the spark was present and strong...remove the carb < a few winds of electrical tape around the starter will keep the 2 halves together when you remove it..note the tab on the bottom of the cup has to go into that hole in the casting when you put the starter back on..also that starter bolt calls for 24 - 30 ft/lbs torque when reattaching >...drain fuel from carb then invert the carb and remove the bowl and set it aside...carb still inverted..do you see the part of the casting that would extend into the bowl?..it's cylindrical and has a brass fitting with a straight slot that's screwed into it. That's your orfice plug or main jet and it needs to be totally clean. If you don't have a screwdriver that fits that slot tightly just clean the jet in place as you can damage those ears pretty easily. Still inverted, you can remove the pivot pin and float, the needle valve with probably come up with the float. Clean the seat and the needle valve, replace the float,needle valve, and pivot pin < the tab on the float arm points towards the body of the carb >. Lastly, remove the brass mixture needle and spray carb cleaner into that passage, note if it comes out the 3 tiny holes behind the the throttle butterfly. Next, blast carb cleaner up those 3 holes to clear them. That passage needs to be clean as this serves as your idle passage then transitions to mid throttle response.Reinsert the idle mixture needle. Clean the float bowl and reattach. You should be able to blow air into the carb through the fuel inlet while the carb is upright. You should not be able to do this when the carb is inverted. While the carb is off, pump the primer bulb from the tank until all the old fuel from the gas lines to the carb has cleared. Reinstall everything, set the idle mixture needle to ~ 1 1/2 turns out from a gentle seat. Pump the carb bowl full again, check your carb roller to timing cam relationship < Leroy covers this > and see how things go. Use caution with that float bowl gasket and you may not have to replace it. Anyway, hopefully just cleaning the carb will get you back out on the 4th.
Andy85
Hi AITn/gm280/kawaboy,
Thanks for the great replies. While you all wrote I put in a new Carb kit including removing the 2 plugs. All of those passages were clear and open and Cleaner would spray through the holes great. The carb looked very clean. I also checked the fuel-pump screen and it was nice and clear so I don't thing crud got sprayed up there. The float was the original cork but appeared to work ok.
Looking at the other replies between yours and the others I think there has to be a timing issue.
My order of operations now,
First, I will check that carb roller to timing cam relationship. Not sure if I need to pull the flywheel for that but I'll figure that out.
Second, I will pull off the flywheel and check the key.
Last summer I backed down a drive way and bottomed the gear-case and prop on the pavement. This is what snapped the swivel bracket. I assumed the swivel bracket was the only damage but there certainly could be something internal.
I did look and the flywheel has an x on the top that appears very close to just behind top dead center (top piston)
There is quite a bit of slop in the twist grip but it has always been like that... The gears look properly meshed according to Leyroy's site.
I also do have a fuel pump rebuild kit just in case but I wont be messing around with that right now as the issue looks to be somewhere else.
Thanks for the replies. I'll likely be done for most of the day on the issue and will update tomorrow.
-Andy
OptsyEagle
This may not be useful but I will mention it anyways. Ignore the writing on the twist grip when starting and just make sure the throttle is turned on completely until is bottoms on the neutral stop. As mentioned above, there should be a mark on the throttle cam under the timing plate that should be in the middle of your carbs roller JUST as it touches that roller. If the cam mark is off to the starboard side of that roller more then an 1/8" when it touches the carb's roller you can pull that rope till the cows come home and she may never start. Basically it is not getting enough gas for starting not to mention the fact that the spark timing would also be off by a little, so that carb roller to timing cam needs to be set right.
Andy85
Thanks Optsy,
I'll take that in advisement. That little roller thing has seen better days and Tons of slop. I may replace that as a matter of course.
Andy85
So adjusting the Link and Sync did not change a thing, it was close anyway. I did notice fuel coming out the front of the Carb:
Is that to much gas and its flooding out right away? I saw that after only 2 pulls.
Andy85
Well flywheel key is sheared. When trying to get the flywheel off the flywheel spins on the spindle and the drive line moves with the ratchet... I still have not gotten it off but now we know what the problem is. any tips?
AlTn
what type of puller are you using?..if harmonic balancer puller..I use an old serpentine belt to hold the flywheel...
60sboater
I use a strap wrench to hold the flywheel on small Mercs 7.5 and 9.8 . I got two at Sears and use the larger one. Not sure if they'll work on your engine.
OptsyEagle
In a pinch, an old piece of external extension cord wire or some nylon strap material, screwed to a 1" thick piece of wood will suffice for a strap wrench. Don't use any thinner wood since you will be putting a lot of torque on that wood and wire/strap material when unscrewing the flywheel nut and off course when you torque it back down again.
Andy85
So it ended up not being sheared. I put the flywheel back on and tried again. Few puffs then nothing. Talked to our maintenance guy at work. Turns out even though the idle needle was set the 1.5 turns out it was way to rich and flooding right away. Works like a charm now.
