15hp evinrude will not start 1974
sambrigman
1974 was running perfect, start rite up and all of a sudden it will not hit a lick. Even with starting fluid nothing. I am getting a spark to the plugs, it may be a little weak spark. but shouldn't it do something with starter fluid. what should I try?? any ideas appreciated because I am lost thanks guys
Lightwin 3
Lose the starting fluid. There is no lubrication in it and it washes down the cylinder walls.
1. Do you have compression on both cylinders?
2. Put some pre-mixed fuel in a spray bottle and spray in carb throat. Any fire?
F_R
Try a new set of spark plugs. Those things were notorious for fouling plugs. Even the factory couldn't fix them.
TN-25
Unlike most other OMCs that liked Champion J6Js, those low tension 9.9 & 15 through '76 liked NGK B7HS.
Harry B.
Weird when things go south with old and some new two strokes that the culprit is the plugs.
