93waverunner
- May 20, 2006
- 17
So i am under the assumption that if i replace the pumphousing on my yamaha pro vrx with one that has the replaceable wear ring, it should restore my top end, because i think that the impeller is in good condition. There seems to be very little space if any between the housing and the impeller, is this good or bad? I am hoping that the housing is the reason, becasue the engine runs fine but i just cant get the ski to stop the rpm's from bouncing toward top even though my speed isn't that great. I just want to know if that plastic wear ring is a good thing to get because i have heard that the stock stainless liner bumps out from corrosion.<br /> <br />If this doesn't fix the problem, i guess it has to be the impeller.
