25whaler
- Nov 24, 2003
- 33
Hope everyone enjoyed the Holidays. I have twin 150 johnsons (1986) recently installed temp gauges. I have installed a sending unit on each head and a toggle switch to go back and forth between port/stbd on each motor. This weekend was the first run with it. The heads (all 4) idle at 140 degrees but when I run the temp drops down to 80 or 90. T stats are all new this year. My question is ... is this normal? I thought the t stats were supposed to keep the temp around the 140 range. I am worried of carbon build up at low temp also could the water be blowing past the t stat at the poppet valves?? if so what is the remedy? Thought it was weird that all 4 were doing this if it was not normal Thanks
