Re: 150hp running 40mph
There is a lot more to correct setup than just prop pitch. Poorly set up boat with 150, 40 MPH, correctly set up boat with 150, 55-60.<br /><br />We need to know how long you have owned the boat, if it has always ran this way, how far is the ventilation plate from the bottom of the boat, stainless steel or aluminum, are the numbers you are giving us at WOT with full trim. Many things may be problematic.
