I have a problem with bogging above~3200rpm. Cold or hot and only under load Starts and runs well below that. Let me post a quick time line as I have spent a lot of time and $ on this including 3 trips to certified Yamaha mechanics
1 boat purchased at auction runs ok but bogs at ~3krpm
2 mechanic tune up same thing
3 carbs rebuilt same thing
I now put an external tank with new fuel and lines and primer bulb to the engine to eliminate bad gas and/or lines
4 mechanic says 2 carbs ng and not repairable wants $1500 to repair
5 bought "rebuilt" carbs I installed with the exact same results
6 brought to another yamaha mechanic checked timing, carb sync,linkage,oil pumps, and installed installed new fuel pumps
EXACT same results
One hint if while under load I by hand open the butterflys (fuel) while closing the choke se'll take off and go 5000rpm??
called another mechanic same line "let me take a look" Any ideas?? Thanks in advance Tom
EXACT same results
