150 V6 2 stroke rough in gear at idle speed
QBhoy
Hi all.
A friend just bought a new to him boat with a mariner magnum 150 v6. Same as the merc 150 v6 2 stroke. Will likely be an early 90’s thing.
At idle it has higher rpm than it should. First thing I noticed, so it’s quite violent going into gear. At a guess it will be doing about 1200 rpm or close to each side of that. So thought no big deal..just needs an adjustment. But then after warming it up at the slipway. We head up the river. At its idle speed when in gear and even a little higher than idle...it almost sounds as if it’s missing or dropping its ignition on a cylinder or two. Very smokey (much more than it should be and mix is correct). Take it out of gear and the rpm shoots up again. Into gear it’s very low and almost cutting out and missing or rough sounding.
I’m now thinking that the previous owner has adjusted the idle speed to try and counter another issue that causes the low rpm in gear at idle.
The owner has changed the plugs but no difference. If it was a different engine with an alpha, I’d almost swear the shift interrupter switch was being activated when it’s in gear. If you get what I mean.
Sounds lovely at higher rpm and plenty of power when throttle opened.
Compression all good and around 115-120 on them all.
Any pointers ? Thanks.
w2much
Check the timing and linc and sync . You may want to have a factory manual for that engine to do this properly, it will pay for itself in time.
Dukedog
could be 'lectric?.. could be fuel delivery?.. need ta figure out what motor is first.. jus plain 150 Mag (same as XR2) is gonna be 2.0 150.. clam shell ('88 and older) or bucket ('89 mixture of both) cowl?.. pictures of power head, both sides and front?..
Dukedog
no clam shell after '89................'91 would be whats called a "fat block" (2.5 style block on outside)... there will be a build date stamped here (picture) in 1/8' numbers.. m/d/yr. base of no. two, block half, kinda behind tha "bend" in tha timing arm.
achris
More fish than mountain goat
Find the engine serial number and we can give you the exact year. (serial number will be a 0, then a letter, then 6 numbers)
It's going to look something like this...
QBhoy
Cheers. Will do. It defo looks like a clamshell to me. He says it’s 91. Maybe it isn’t. Looks identical to my 88/89 Merc 150 black max. Except says mariner magnum 150 on it.
emoney
There were definitely some early 90 year models that had that "Clamshell look" if nothing else in the 150hp and up range. Never had one off so not sure if it was truly a clamshell or just had the same shape to it in a single bucket.
Oh, and my vote would be a "lync * sync" as well. I would definitely get a factory manual and it will walk you through the process, step-by-step with good pics/illustrations.
