150 HP Johnston Faststrike Alarm issue need help
dfrank330
I have a 1979 150 HP Fastrike FICHT and have this issue: Starts and Runs fine however after being started for a few min. and moving away from the dock the alarm comes on. It times out in about a min. and the check engine light stays on. Once I am running down the lake the light goes out and runs fine. When I stop to fish and go back to idle the alarm will come back on in a min or two and stay on till it times out and the check engine light stays on till I go again.
What are your thoughts?
I took it to a dealer and he said when he plugged it in to the computer it stated water in the fuel. However I have tried dry gas and no change. Thanks for your help.
Faztbullet
If dealer told you water in fuel drain and flush system...fuel driers don't make water go away as it attaches to water and carries it thru system
Rustywrench
Common computer glitch with early Ficht engines. False water in fuel code. Your computer can be updated. Get in touch with Eric @ Marine Computer Supply. 844-627-2255 Mobile, AL. He can confirm your problem & advise how to proceed.
