150 force no start (wiring)
Marquiss
150 Force just turns over fine no sign of trying to start ( Bought boat at Auction) looks like a Big Mistake
How would I Know what type wiring, I think some one has changed the wiring.
This is what I have Model 1508C91D Serial 024237 Made US Marine Switch box #116-7323 Spark plugs #L76V champion
(Numbers on coil 2060 blue), engine # P741294
mikes 86
Re: 150 force no start (wiring)
check your kill switch, should be pulled out has small saftey cable on it,should be around shift lever, engine will not start but will turn over
Marquiss
The cable is on the safety switch.
THere is black and yellow wire at the safety switch that go to the ignition then to the switch box is it + or power to it ?
There is no spark at the spark plugs or at the coil on all 5 ?
bentle
If you don't have a manual for you motor yet then it would be a great investment
for you. It is chucked clear full of info on yr motor including wiring. I was wondering though
if the stater and trigger are still on the motor located under the fly wheel. Only asking cause you stated that the boat came from an auction and ya never know who did what before you got it.
SwampThing
Did someone say Force Manuals?
