150 evinrude spitfire seires dying at high speeds
jbird79
guys I need some help im pulling my hair out, I have a evinrude 150hp spitfire series motor it starts rite up and runs great for about 10 to 15 min then just suddenly dies especially at high speeds and was very hard to start back up until I replaced VRO pump, spark plugs, water pump, and the regulator rectifier well now it will start rite back up after dying and will sometimes get back up to full speed but always eventually suddenly dies no sputters at all I do not believe im losing fire like I initially thought it really seams like im either losing fuel or possibly getting air in the fuel system because before replacing all that above stuff I would have to bleed air out before it would even start back up yalls thoughts are greatly appreciated.
Bosunsmate
Have you done a compression test?
Have you had someone prime the bulb when it stumbles to check it aint a fuelpump failing?
Bosunsmate
You should also check that spark jumps a 7/16 gap on all cylinders when the motors hot as electronics tend to fail first with heat when their times almost up
