Re: 15 hp Johnson Compression
I think if you do it right, you can add the fresh premix on top of the seafoam mix. You are only mixing a small amount of seafoam, then running it for a while. Then you let it sit awile and then run it awhile. Let it sit a gain and change plugs add premix to tank and go.
Initially you add 12 oz to a gallon, run it twice. Lets say you still have a gallon. Now you add 5 more gallons of premix (assuming a 6 gallon tank), now the ratio is 12 oz to six gallons. 2 oz per gallon. This is the maintenance ratio, should be fine.
