15 HP Gamefisher
Clea
Help, I'm here again, I've got a 15 HP Gamefisher, Replaced Water Pump and It putting out Water. When you put motor under power for about 2 to 3 minutes, Motor runs Hot and cuts off. Its like the motor seizes up. And also motor will Idle, and again, When you get under power have to squeeze bulb to keep fuel going. Did replace all fuel lines and filter. Anyone have any Ideas. Please Help, Bout ready to use motor for an Anchor.
jerryjerry05
Re: 15 HP Gamefisher
Did you just install this motor on the pontoon boat?
Sounds like the pump or lower unit wasn't installed right.
The fuel pump probably needs replacing or rebuilding.J
Clea
This motor is on a jon boat. Seems like it does fine pumping water when at idle. It does not have a thermostat in it.
