15 hp gamefisher Help
fishstory
Got it from cousin, who said it had little use. the kill switch does not work, (neither one of them). Bought a new kill switch and that does not stop motor. What do I need to do?? Mdl #225581505, and what would be the year of this motor?:confused:
highcountry
Re: 15 hp gamefisher Help
My guess would be to put an ohm test on the wires at the kill switch and see if the wires are grounding like they should.
fishstory
I don't have a ohm tester, but I did discover that none of the wires were grounded under the flywheel. Put them on and still nothing, will try ohm test next. Many Thanks
