I have a 1999 15 hp Merc that I use as a kicker motor for trolling. It will run good for a few an hour then stall the primer bulb is soft. I pump the bulb back up and it will start and run for just a few minutes long enough to use the fuel that was pumped into it I can pump the bulb and it will stay running. It is hooked up to a built in fuel tank with its own pickup. I have replaced the bulb twice had all the fuel lines replaced from the tank to the motor and all the fuel lines inside the motor with a new inline filter mercury brand. The fuel pump is new from mercury and the carburetor has been rebuilt twice by two different mechanics. I also took the fuel line and put a tee in the line for my main motor (which runs fine) and tried that and the same problem. Pulled the floor up to get to the fuel tank pulled out the dip tube and the screen was not plugged. Pressure tested the fuel system and had no leaks. Also put a new water impeller in. I don't know where to turn next anybody have any other suggestions
