140wt gear oil
nwcove
any suggestions on where to find 140wt gear oil? called around and can get 90wt, but 140wt is whats needed?
nwcove
Re: 140wt gear oil
its for a british seagull, from my what i can find out, the gearcase needs 140wt oil, its designed to let the oil and water mix! no real seals in the gearbox. just cant find 140wt, but supposedly its common for farm equipment.....i live in a fishing village , so the farm deal isnt working out.
help! lol
5150abf
Re: 140wt gear oil
Jeez 140wt, wouldn't that come in a block, that is some thick oil.
I just googled it and came up with all kinds of places to buy it, whether they can ship to Canada I don't know but it is out there, even found this http://britishseagullparts.com/gear-oil.htm
nwcove
Re: 140wt gear oil
lol....i agree, thought maybe i can squeeze butter into the gear case! gunna have to make some more calls.
Chris1956
Re: 140wt gear oil
That gear oil is usually avail at auto parts stores, at least here in the US. I was able to ruin a transmission with it.
robert graham
Re: 140wt gear oil
If you just can't find the 140Wt. gear oil, then maybe try the 80-90Wt. with some STP added to "thicken it up". Maybe add some O-Rings to help seal prop shaft? Tractor Supply carries 140Wt. Gear Oil. Good Luck!
