140hp Johnson
hotrod261
1985 Johnson 140hp J140TLC0 smokes when i start it. Its running rough and coughs at idel. Pulled plugs they look wet. So I took off air silencer and the bottom had a pool of oil. Also the carbs looked wet with oil. I did do compression check all cyclenders were at about 120PSI.
Dhadley
Re: 140hp Johnson
Welcome!!<br /><br />Theres lots of reasons for the smoking but the rest is normal for that style looper.<br /><br />Start with the basics and tell us about your motor. Are you using the VRO or pewmixing? What oil? What grade fuel? Very important -- what spark plugs?<br /><br />Enough questions for now.
hotrod261
Re: 140hp Johnson
Yes i am using the VRO with Johnson oil and 92 grade fuel. Plugs are L77J4
walleyehed
Re: 140hp Johnson
Just a guess here, But I'd bet Dhadley will back me when I say 87 octane would be best in that engine..<br />Bulb not getting (staying) hard could be a couple of things...If it has a check-valve in-line, sticking.....needles not seating in the carbs, or possibly a bad bulb.<br />Also, with VRO equiped engines, you should have QL77JC4's for plugs, although I'm not sure that would cause your problem...<br />You may need to puncture the diaphram in the VRO tank cap as it sounds as though you may be getting some pressure build-up forcing oil in, and that WILL make it smoke like mad on start-up, and run rough for awhile. I think it's coughing because your bowls are half oil and half fuel on start-up causing a lean condition.<br />I would go back to 87-89 octane fuel. Remove cap to VRO tank, with a paperclip cut at a 45 deg angle or so, turn the cap over so you are looking at the inside of the cap and press the paperclip through the center hole until you feel the diaphram pop....you'll feel the clip poke through...this will keep the oil from being forced into the bowls as fuel evaporates.
walleyehed
Re: 140hp Johnson
Lets see what dhadley has to say about this...He'll catch it tommarow I would guess.
Dhadley
Re: 140hp Johnson
In addition to Walleyehed's advise you might look for a fuel restriction. It should pump more oil if theres a fuel restriction.
