140 hp outdrive with 120 hp motor
OMC73
This is my set up right now on a project boat I got. I haven't been in the water with it yet. The number on the out drive is 980308. Is this not going to work with my motor?
only difference is the sticker. difference in the motor is 1/4" inch stroke
OMC73
Ok. I've been told there is a difference in the gearing between the 140 vs.120 outdrive and the way I understood it was that the 120hp motor is under powered for a 140 hp outdrive.
Same outdrive, same gears, different sticker
southkogs
Scott knows these drives better'n me, but I have the 140 and the 120 uppers with different ratios (19.20 & 16.20 respectively) like I put in your other topic. Lowers are all the same (15.23).
BUT - the 980308 number you have listed is one I can't find. I think it's the part number of the upper gear case housing, but I can't confirm that. So, I wouldn't be too convinced you've got the 140 gearing just yet. The difference in gear ratio (I think) is slight enough that you can re-prop if the boat doesn't perform well. If it turns free - run it.
OMC73
Okay, well I suppose if I ever get the thing in the water we'll find out lol.
OMC73
Getting ready to do the impeller on the out drive so I have the gear case off. I counted the pinion gear and it has 19 teeth. From what I'm reading it should have 20 teeth for a 120 HP motor. Sorry for beating a dead horse here but I thought I'd share what I found.
southkogs
The pinion gear is different between the two, but I don't know the teeth count.
OMC73
Maybe I called it the wrong name. I'm talking about the gear in the gear case that is turned by the ball gears. Well I can't get the link to work.
southkogs
Not sure what your link was, but I know the gear. There are two different part numbers for the 120 and the 140 (and another again for the 165). I don't know tooth counts without looking for some pictures though - I can do that later tonight.
OMC73
I got # 0979925 for the 120 and 0979855 for the 140
southkogs
Teeth count is correct, as are your part numbers.
I didn't realize this before looking that they correspond with the gear ratio directly too (I've not broken into the gear boxes much).
