Re: 14' Row boat with battery in the bow motor in the stern
Yes, auto wire works. What you want is some sort of quick disconnect on the battery. The wing nut posts and ring terminals are good for that - fairly quick/easy. Then, you will want the wire running to the stern where the TM is. Have a big TM plug at the TM end. Will make it easy to remove.
http://www.iboats.com/Sierra_2_Wire...d.216598--list_time.1184909801--view_id.45007
Then, you will need some sort of split off with smaller wire to the fish finder. Have a small plug there for easy removal.
http://www.iboats.com/Seachoice_Mol...d.216598--list_time.1184909801--view_id.21873
If you have lights, you are gonna want them on a pole, that remove from their bases or a fixed on on the bowsprit. I hope I shouldn't have to say this, but you only need these if running at night.
http://www.iboats.com/Perko_Combina....236390--list_time.1184910041--view_id.239640
http://www.iboats.com/Seachoice_Bi_...id.236390--list_time.1184910041--view_id.2833
You also will need a stern light. It has to be on a pole.
http://www.iboats.com/Adjustable_He....236391--list_time.1184910301--view_id.341472
You can have them either with plugs like the FF has, and plug them in to use them, or have a three position toggle, so that one position is off, one is both bow and stern lights, and one is just stern light. (bow light doesn't need to be on when not moving) You need to make sure the toggle has On/off/on, and not just on/off.
http://www.iboats.com/Designer_Seri...d.216627--list_time.1184910531--view_id.39650
If you decide to have a bilge pump, you will probably hard wire it and have a two position toggle, or you could have one with a float switch, and a plug like the FF has.
Now, these are NOT the lowest prices. I did this in a hurry, just to give a quick reference, and usually grabbed the first on the page. You can do this a LOT cheaper. Much of this stuff can be had at your local advance auto parts. You don't necessarily need marine stuff, except the navigation lights. Hope this was helpful, and I hope I didn't miss nothing.
